Order Ford 8N Parts Online
8N FORD
STEVE MASON
05-20-1999 07:25:40
MY 1951 8N IS STARTING TO HAVE WATER IN THE OIL. AFTER USING IT FOR SEVERAL HOURS THE WATER IN THE RADIATOR IS DOWN A BIT. THE OIL IS A GRAYISH COLOR. CAN ANY ONE PLEASE GIVE ME A LIST OF THE MOST PROBABLE CAUSES? COULD THE SEAL BETWEEN THE SLEEVES AND THE BLOCK BE LEAKING,MAYBE A BLOWN HEAD GASKET. ANY INFO WOULD BE GREATLY APPRECIATED.THE TRACTOR STILL RUNS FINE.
Wayne (NC)
05-20-1999 08:56:04
 Re: 8N FORD in reply to STEVE MASON, 05-20-1999 07:25:40
Steve,
Dell is right. I just got through with a complete overhaul because of the same problem. I was convinced that the block had a crack but it turned out that the head was warped and the head gasket was leaking --- in a big way. When I removed the head there was about a cup of water on top of the piston. I assume this was getting past the rings as it sat and into the oil sump. Surprising thing was how well it ran despite this problem. I think it was leaking only when it was first stopped and allowed to cool down.
Dell (WA)
05-20-1999 07:57:22
Steve..... ...Most likely problem is a "blown head gasket". Block sleeves are "dry".
Check for a "warped" head. If warped, have a machine shop "skim" or mill the head true.
Good Luck..... .Dell
