Order Ford 8N Parts Online
8N Ammeter
Art in Cortez,
09-09-2007 18:42:10
Hi All,
First thank you all for all of your helpful input on other posts I have added to this board. The collective expertise of the participants is amazing!
I have a "47 8N S/N 2185 front mount 6 volt. My question has to do with a lack of ammeter readings. I recently replaced my old ammeter with a new one. The old one did not seem to read anything and was the old induction type with the wire merely passing through a loop on the rear. I cut that wire and added terminal rings and secured the terminals to the new meter ( after accidentally grounding one side which created a major spark). the wire was hot from the battery without the ignition switch (a two position push/pull switch) being pulled to the on position. There does not seem to be any needle movement when the switch is turned on or when the tractor is running. It would seem to me that when the ignition switch is pulled on there should be some indication of discharge and when the tractor is running there should be a charge indication. The needle does not move at all.
I am not an electrical type so trouble shooting isn"t readily apparent for me. What is the best way to check the generator for output and is it possible that the wrong wire might have run through the original ammeter when I acquired the tractor?
There are not very many wires run on the tractor. It does not have lights ... yet.
Any thoughts/suggestions would be most welcome.
Thanks in advance.
Art in Cortez, CO.
soundguy
09-10-2007 06:24:52
 Re: 8N Ammeter in reply to Art in Cortez, Co., 09-09-2007 18:42:10
Make sure your wireing is OEM.. otherwise your meter may not correctly measure net charge / discharge.
Study that diagram.. it will be obvious why yhr ammeter side was hot with no key switch on.
Soundguy
JMOR
09-09-2007 19:26:23
For a wiring diagram, see the post earlier today titled "8N Lights" , Bob included diagrams. When you shorted things, was that current flowing thru your meter? If yes, meter probably toast, as meter good for maybe 30 amps & battery can supply 100+ amps.
Hook a bulb from meter to ground & see if it moves when bulb lights. Try both terminals, one at a time with bulb from either terminal to chassis ground.
Joe)NYC)
09-09-2007 19:10:46
Art,
One way to check if your generator is working is to first with the engine off, using a meter on the DC VOLT scale(10 volt scale is OK) touch the RED lead to the positive(+) side of the battery and the BLACK lead to the negative (-) side of the battery. Read the meter it should read 6 volts. Now take the leads off the battery. Start the engine and run it at roughly 1000 RPM, Place the leads on the battery just as before and take the reading. If the reading is 6 volts or less the generator is not putting any juice out. If it reads 13 to 14 volts the generator is charging your battery. Tis is a simple test as I have been using. Others may have more detailed or complicated setups.
Art in Cortez, Co.
09-09-2007 19:20:40
 Re: 8N Ammeter in reply to Joe)NYC), 09-09-2007 19:10:46
Joe,
Thanks, that makes sense, is simple and I'll definately give it a try.
Art
