1 wire genny
1941 9N Tom
09-11-2007 03:24:15
How do you adjust the 1 wire genny on 1941 9n ?
Dan
09-11-2007 04:39:53
 Re: 1 wire genny in reply to 1941 9N Tom, 09-11-2007 03:24:15
Should be a screw adjustment on the end cap of the genny that if you look REAL close, you can hee a "High" and a "Low" with arrows showing you how to turn the screw to achieve the results you are looking for. Try to keep it as low as possible during normal use, use High only in times you are drawing a lot of current - like running with the headlights on - or you will cook your battery quick.
HTH,
Dan
1941 9N Tom
09-11-2007 05:34:35
 Re: 1 wire genny in reply to Dan, 09-11-2007 04:39:53
Thank -You very much for your help!
