I FOUND IT!!
Pete-N-Ga
09-11-2007 19:42:07
Been looking for the secret bolt to add grease to the steering sector for my 8N (8N406169). I"ve actually had the bolt out but just tonight I found that it had a hole in the back. Now, how do you get the grease forced into the hole? It"s 7/16-14 threads. do you have to make an adapter for a grease zerk? Can you buy it already made? thanks in advance for the help, you guys have been a great help in the past for me.
Dave H
09-12-2007 18:03:20
 Re: I FOUND IT!! in reply to Pete-N-Ga, 09-11-2007 19:42:07
Hal, swat I was thinking also!!
Dave H
09-12-2007 04:56:25
This is getting interesting. I have a late model box that has the oil fill plug on the left side behind the dash brace/frame.
8N'r--WI
09-12-2007 04:15:26
 Re: I FOUND IT!!--Another Option in reply to Pete-N-Ga, 09-11-2007 19:42:07
Pete--you can buy a brass "reducer" fitting at Home Depot that will screw right into the steering box and the grease zerk screws right into the other end. About $1.75 plus cost of the trip.
third party image
Tim
hal@nc
09-12-2007 17:16:35
 Re: I FOUND IT!!--Another Option in reply to 8N'r--WI, 09-12-2007 04:15:26
Correct me if I'm wrong but I thought brass threads were pipe threads and different than the bolt threads in the steering box. Of course after a couple of turns the brass threads would probably give enough to at least work. The same thing with the zerk fitting (?)
8N'r--WI
09-13-2007 04:51:18
 Re: I FOUND IT!!--Another Option in reply to hal@nc, 09-12-2007 17:16:35
Hal---you are right, however, the early style steering boxes (like the one of my 49 8N shown in the picture) actually used a 1/4" pipe plug(original part #358061) instead of a regular bolt for the filler plug.
My 51 8N uses the regular bolt thread.
The brass reducer is a perfect fit where the 1/4" pipe plug used to be and a large grease zerk will screw right into the reduced end.
HTH----Tim
Hal@NC
09-13-2007 05:16:30
 Re: I FOUND IT!!--Another Option in reply to 8N'r--WI, 09-13-2007 04:51:18
Thanks for the info!. Thats really good to know. I have a 51 and 52 and they both have standard threads
Pete-N-Ga
09-11-2007 20:10:33
Thanks Dan, got it ordered.
Dan
09-11-2007 19:45:19
Clicky below...
Dan
