Spark Plugs
Ron Simia
09-12-2007 10:29:58
I have been using the following plugs gapped at .034:
Champion (Copper Plus) 857 RH 18Y
They seem to foul, i.e. black carbon, pretty easily. Is there a hotter plug I should try? I can't get higher voltage and I can't do more with the carburetor.
Any ideas?
Ron Simia
Cleveland,Ohio
old
09-12-2007 13:31:17
 Re: Spark Plugs in reply to Ron Simia, 09-12-2007 10:29:58
Would help if we knew what tractor you have. But taking a guess I would say you have them gapped to wide and should be around .025 and you also have your carb set to rich and need to turn the main jet in a turn or so
CENTAUR
09-12-2007 10:41:03
I do not see the engine or carburetor make or model? CENTAUR
soundguy
09-12-2007 10:36:49
Not sure what machine you have?
N's run pretty good on AL437's and .025 gap
Higher gap will get you a bit more kv befor ethe arc, if you have it.
I also bleieve your plug is a resistor plug... not real great on breaker ignition systems unless you got an AM radio in there somewhere..
Soundguy
