original radiator I believe - what do these mean?
high pockets
09-12-2007 17:09:54
I've started piddling with Granpa's old 9N and I believe this radior to be original given the stamping on the front.
third party image
I found these on the back side...
third party image
third party image
Anyone able to tell me what they mean?
full view of radiator...before I started trying to clean it up a little
third party image
in this photo you can see the sheet metal straps on the side... they've been soldered or braized directly to the top of the radiator at some point in it's life.
Bob
09-12-2007 20:53:39
 Re: original radiator I believe - what do these mean? in reply to high pockets, 09-12-2007 17:09:54
I'm NOT sure if the little soldered-on numbered tabs COULD have been from the factory, HOWEVER, sometimes radiator shops solder on little tabs with "code" on them to identify the radiator as one they have worked on, if it comes back for warranty work, or whatever.
Dan
09-12-2007 19:22:07
You have an original early 9N non-pressurized radiator - and in great shape. The sheet metal staps you refer to are original and not added on. I have been looking for a good one for my 1939 9N for quite some time - you have a treasure there, take care of it.
Dan
brian q
09-12-2007 18:36:46
Looks just like the radiator out of a 41 Ford 4 cylinder pickup I had. Still have the rad and engine/trans in barn. Guess what? The rad and engine block have 9N casting numbers, though the engine has a mechanical fuel pump.
