Engine Paint
Cryptkeeper
09-16-2007 17:06:36
OK, so everybody knows I am trying to get this old 9N going. I got 'er runnin' good. Now, can I use XO-Rust to paint the engine and will it last?
I am using a BRUSH!!! (Pain).
Thx in advance.
NewYorkTom
09-17-2007 15:00:11
 Re: Engine Paint in reply to Cryptkeeper, 09-16-2007 17:06:36
I used the True Value XO paint (Tractor Red) on my '41 9N chassis including engine. It went on real well with a brush, hid alot of imperfections and is holding up really good on the engine. I used the spray can of the same paint on the small removalble parts.
soundguy
09-16-2007 18:17:28
Ditto what dave said. When i spray my tractors, the engine gets the same paint as the rest of the cast.. etc.
Soundguy
Lance in Brenham, TX
09-17-2007 20:21:04
 Re: Engine Paint in reply to soundguy, 09-16-2007 18:17:28
What about exhaust manifolds?
soundguy
09-18-2007 06:26:16
 Re: Engine Paint in reply to Lance in Brenham, TX, 09-17-2007 20:21:04
On some of mine i paint em like the factory did and just let it burn off. on others I actually used hi-temp BBQ black paint.. etc.
soundguy
Zeusdog
09-17-2007 22:12:30
Lance,
Right there in Brenham at that auto parts across from Southerlands, I found some what I think they called extreme manifold paint. Put in on a new exhaust and followed directions. Wish I'd read them before gettin two cans cause according to the specs on the can you want a pretty light coat. After curing it by starting and idling for 10 minutes first. Cool down and repeat for 20 minutes. After that run it normal. Holding up real good.
Contact me if you need the extra can ;-)
david_d@hughes.net or during the week at
david.donovan@heidelberg.com
DennyF
09-17-2007 20:27:16
Fogged mine with Krylon BBQ paint in matte black (before painting the intake and engine in red), ditto for the tail pipes.
Dave H
09-16-2007 17:43:21
I don't know what XO is but I paint engines with the same paint i paint the tractors.
