Manifold stud
Andy
02-06-2000 16:34:29
In process of changing intake/exhaust manifold. Nut did not come off, entire stud did. Have separated them but need to know best procedure to reset the stud. Do you use any type lock-tite or just re-thread and re-torque when installing nut?
Appreciate any input.
Thanks.
Sam (Mo.)
02-06-2000 18:14:28
 Re: Manifold stud in reply to Andy, 02-06-2000 16:34:29
With mine, I think two nuts came off and two studs came out with the nuts. I don't think it matters, just clean the threads on the studs and put 'em back.
I had a couple of brass nuts, which I think are original. Brass nuts should keep the nut from seizing to the stud, so that's probably a good thing.
