Texas Gushers!
AnvilheadTX
09-18-2007 10:05:22
I pulled the two bolts that hold the heat shield/wire loom to my block last night and much to my suprise coolant came gushing out of the holes. Is this supposed to happen? I drained the radiator a bit and the gushers stopped.
On a side note, one of the bolts was too short and was never threaded into the block.....could this have an affect on operations????
old
09-18-2007 13:29:00
 Re: Texas Gushers! in reply to AnvilheadTX, 09-18-2007 10:05:22
If the one bolt is to short yes it can cause a problem with the head gasket blowing because of improper torque on the head. All head blots need to be torqued down to the correct FT/LBS or it can cause problems
Brian Bell
09-18-2007 10:46:33
It's quite possible. Where were the bolts at? In the head or on the side of the block? I think that most of the head bolts either to thru the water jacket and intake/exhaust ports. All of the intake/exhaust manifold bolts are in the water jacket.
