Order Ford 8N Parts Online
brokeded my mower wheel real bad-like with my 8N
artroland
09-19-2007 21:25:40
OK. So my Ford 8N is stronger than my BMB"s rear wheel assembly, and in an ill conceived attempt and backing into an area to mow it, only to discover a BIG stone the hard way, I broke the rear wheel assembly.
As stated, it was broke real bad like.
Now, before you simply suggest that I easily weld it back in place, it"s been welded a time or two and I was hoping someone could point me down the path to finding a potential replacement, even for something that might be generic and need a bit of customization to fit it.
Any ideas? Thanks!
artroland
09-20-2007 15:30:42
 Re: brokeded my mower wheel real bad-like with my 8N in reply to artroland, 09-19-2007 21:25:40
third party image
Here you go ...
soundguy
09-20-2007 06:00:31
Post a pic so we can see what is damaged and what you have to work with.
is the hub/wheel itself damaged.. or the fram and axle / spindle.. etc..??
Soundguy
JerryCPP(WA)
09-19-2007 22:32:26
I don't know what a BMB looks like, but when my old Ford 60" crazy wheel died, I bought an axle stub, bearings, hub, and wheel from Surplus Center. The original had a yoke with a through-axle, so I cut off on side of the yoke and welded the axle stub on. It's been working great for a few years now, and the roller bearing setup is far superior to the old cheapy ball bearing axle and wheel.
artroland
09-22-2007 18:14:58
 Re: brokeded my mower wheel real bad-like with my 8N in reply to JerryCPP(WA), 09-19-2007 22:32:26
Bump
