Jubilee 53
Rod in Memphis
09-21-2007 07:17:23
I have been reading this sight for about 3 months, ever since my purchase of my first tractor. There is a lot of knowledge being shared on this sight. Soundguy and many others have helped newbe's in a lot of different areas.
I have seen many wiring digrams converting 6 volt postive grd. to 12 volt neg. grd. for the 2, 9 and 8 N's. Would the 8 N conversion to 12 volt neg. gd. with side mounted dist. be the same for the NAA's? When I stole my girl ($1,600.00) someone had converted her to 12 volt neg. ground with wires going every way, but with new 12 v. alternator and I think 12 volt coil. I have had one issue with the switch but the sparkie guy fixed that for me. I would like to make sure that the conversion is correct. Sorry for the rambling. Thanks
Rod in Memphis
12-18-2007 09:08:00
 Re: Jubilee 53 in reply to Rod in Memphis, 09-21-2007 07:17:23
Bob the latter part of Sept. you replyed to a request from me for wiring digram for a Jubilee 12 volt neg. grd. I just finished re-wiring her complete with 10 and 12 ga. wire, a 12 v. coil, new ign. & light switches. It is amazing, turned the new ign. switch to the on position the 194 bulb lit, hit the starter and seemed like a half a turn cranked and ran smooth as silk. Even the 194 bulb (resister)went off when cranked. There is hope for the week end piddler. Thanks for your help
Bob
09-21-2007 08:21:36
Yes, the conversion is very much the same. Here is a diagram of the 6-Volt system on an NAA.
Third Party Image
Compare that to a 12-Volt conversion diagram for a late 8N, and you'll see it's the same, except for the 12-Volt alternator and assiciated conversion wiring.
Third Party Image
