PTO Shaft seal
Paul Farley
09-22-2007 17:57:12
Hi Folks,
My new PTO shaft seal is about 1/4 inch thiner than the old one that has a felt wiper on the outside.
I assume if I install the inner retainer ring I can press the seal in from the outer side and stop at the retainer ring.
Also the seal has a small stainless spring around the seal on one side. Does this side (with the spring) face the outside?
Thanks Folks
PaulF
Tom N MS
09-22-2007 18:06:13
 Re: PTO Shaft seal in reply to Paul Farley, 09-22-2007 17:57:12
Lip with the spring around it goes inside.
Paul Farley
09-22-2007 18:21:59
 Re: PTO Shaft seal in reply to Tom N MS, 09-22-2007 18:06:13
Thanks Tom!
PaulF
