Thanks Everyone...
Alan R
09-23-2007 10:48:43
Now that my 52 8N is running well, I just realized how much I have relied on all the expertise here to get it running. When I bought the tractor, I was looking for a cheap working tractor, unfortunately, it needed quite a bit of work to repair the blown head gasket and accumulated crud that had been left sitting in the engine for a few years before I got it. While I haven't done a full restoration, at least the tractor now runs well and I can actually drive it. My chore today was changing the hydraulic oil. That was quite an experience, but again, I checked here first, to find out what type of fluid to use and how to change it. I knew I had a lot of water in the fluid, but was surprised when I loosened the plug for the hydraulics (the center plug between the tranny and differential) and at least 2 cups of pure water came out before I got to anything remotely resembling oil. Yuck! After allowing things to drain for a few hours, (changed the engine oil in the meantime) I refilled and replaced the boot on top of the shifter for good measure, then replaced the drain plugs and fired her up. After running around for a while, the fluid looked clear and everything sounds and looks good. I know there will always be something in need of attention (this is a working tractor), but I just wanted to say that I really appreciate all of the help and knowledge I've gained from this group. Hmmm...I may need to tackle those worn brakes soon, and those tires are pretty worn...may need a few bushings up front...is that valve cover leaking? Oh well, got to go. Thanks again.
