Transmision Center Housing Split
Sean (TX)
09-23-2007 11:11:05
Noticed a weird noise at the rear of my tranny after 4 hours of brush hogging. Plan is to do it under a shade tree. I want to roll the rear end away from the tranny. Looks like the best way to go about it. Any tips or tricks? Words of wisdom? can trailer jacks with a wheel be mounted to the PTO inspection ports? Have seen it done in pics on the front of the tranny. Like to mount those before I roll the rear back..
Sean (TX)
09-24-2007 14:28:25
 Re: Transmision Center Housing Split in reply to Sean (TX), 09-23-2007 11:11:05
Im thinking the non swivel type will be stronger. Im going to look at them in the next day or two. I got some big honking timbers today. 4X12. Going to cut them to 24" lengths. Cleaning the sump with Diesel. Going to let it soak a few days. Must of the sluge is broken up already.
Ramrod
09-24-2007 14:02:29
 Re: Transmision Center Housing Split in reply to Iron Rose Farms, 09-23-2007 11:11:05
I think I would put two on, or go heavy duty, as these have been know to break and fall, costing a broken casting and big bucks to replace. I would also block it up after it is split regardless of method.
_____ _____ _____ __
Ramrod
James 1:19
third party image
Sean (TX)
09-24-2007 13:13:34
 Re: Transmision Center Housing Split in reply to GB in MT., 09-23-2007 11:11:05
This looks like a winning method...
third party image
third party image
Sean (TX)
09-23-2007 15:42:40
 Re: Transmision Center Housing Split in reply to 2fordsmike, 09-23-2007 11:11:05
drained the fluids found some thin strips of metal. My guess is they are a bearing caseing??? Found most of them in the drain plug the rest I found with a magnet in the drained oil/... Have 5 gallons of diesel in the tranny now...Is it ok to let it soak for a week?
third party image
Sean (TX)
09-23-2007 13:39:41
 Re: Transmision Center Housing Split in reply to Colin King, 09-23-2007 11:11:05
Going to split the rear half first. Then use a cherry picker to get the tranny off the engine. Kinda daunting task but the best way is to dig in. Drained the diffy. Plus I have the inspection plates of for a closer look. Going to give it a good flush first...
Hobo,NC
09-23-2007 13:29:38
Hate to break yer hart but the fronts gotta come lucy'to.
Sean (TX)
09-23-2007 12:12:09
 Re: Transmision Center Housing Split in reply to Zeusdog, 09-23-2007 11:11:05
john hunt said: (quoted from post at 14:56:45 09/23/07) first take off the brush hog and see if the noise went away it might be drive cause it because it need a little lube and sound do travel
Removed that today...No change in the sound. Does it with or without the pto on. Stops when I depress the clutch. Im convinced it is a bearing on the rear of the counter shaft.
john hunt
09-23-2007 11:56:45
