Order Ford 8N Parts Online
8n PTO CHANGE OUT PROBLEMS
498ntractor
09-23-2007 19:48:42
I bought a conversion kit for my 1949 8N and the new PTO shaft had a sleeve on it and when
I pulled out the old shaft it did not have a sleeve. Of course I could not get the new PTO
to go all the way in. Dose any one know what I Should do. I think I will ethier have to cut the sleeve off the new shaft or try figure out is the old sleeve is still inside stuck some where.
Any help out there!
I also have Business Opportunity for any one that would like to look, It's FREE
soundguy
09-24-2007 04:57:52
 Re: 8n PTO CHANGE OUT PROBLEMS in reply to 498ntractor, 09-23-2007 19:48:42
The 100$ or so pto change out kits are pretty much just unbolt and swap.
i'm not sure what you are talking about by saying 'sleave'
post a pic.
Normally you pull the 4 bolts holding the pto bearing carrier tot he rear housing flange, and then slide the entire assembly out, and the slid ethe new assembly in with a new gasket, install 4 bolts and go.
Soundguy
498ntractor
09-30-2007 13:03:50
 Re: 8n PTO CHANGE OUT PROBLEMS in reply to soundguy, 09-24-2007 04:57:52
Everything's good with my PTO.I paid for the right part but the parts department give me the wrong pto shaft.Thanks for the reply
soundguy
10-01-2007 05:16:27
 Re: 8n PTO CHANGE OUT PROBLEMS in reply to 498ntractor, 09-30-2007 13:03:50
Well.. yeap.. that makes it hard sometimes!!
soundguy
