Brake Problems
RD Tx
09-24-2007 16:56:33
I am having brake problems with my left wheel. It does not matter how much pressure I put on the peddle it does not even slot the tractor down. I can't hear or feel anything grinding like you would from a car. The peddle only goes down about half way down.
Any suggestions would be appreciated.
Thanks,
RD
wwildhorse2k1
09-25-2007 19:37:55
 Re: Brake Problems in reply to RD Tx, 09-24-2007 16:56:33
I had the same problem on one wheel -- the bushing at the end of the brake lever shaft was siezed to the backing plate and would not turn the cam . I could stomp as hard as I could and I was only twisting the brake shaft. I pulled the axle and soaked the bushing and just worked it back and forth until is was free. There are no lube points for this but I give it a shot of wd40 once a year --
soundguy
09-25-2007 05:59:31
Turn that square adjuster and see if you just ran out of shoe for the amount of pedal travel you have..
soundguy
Dunk
09-24-2007 17:01:10
What model is it?
Is it leaking rear end oil on it?
RD Tx
09-24-2007 17:10:38
 Re: Brake Problems in reply to Dunk, 09-24-2007 17:01:10
Sorry I have a 44 2n. No oil leaks around the brakes that is visible.
Thanks,
RD
Dunk
09-24-2007 17:34:28
 Re: Brake Problems in reply to RD Tx, 09-24-2007 17:10:38
I don't know about your 2N some do though.
Have you tried to adjust them.
