Replacing new plug wires
Ricky Kristynik
09-26-2007 05:37:33
I will be helping my Dad work on our 8N this weekend changing to an electronic ignition. I am changing the plug wires and spark plugs and this tractor has a front mount distributor. I want to make sure we wire the plug wires correct. Does anyone have a picture of where the 4 wires go and is plug #1 closest to the front of the tractor and then go from 1-4 to the back? Thanks for your help!
Sean Feeney 2
09-26-2007 15:17:53
 Re: Replacing new plug wires in reply to Ricky Kristynik, 09-26-2007 05:37:33
I put one on my 1940 9n a few weeks back, one of the best $90 every spent.
RP-40-9n
09-26-2007 08:24:43
ricky, i would suggest to change one thing at a time ie, start with elec. ignition and be sure it runs before changeing anything else. if you change everything and it wont run, then you dont know what to fix. RP
Ricky Kristynik
10-01-2007 08:22:20
 Re: Replacing new plug wires in reply to RP-40-9n, 09-26-2007 08:24:43
I put on the new electronic ignition and changed the plugs. What a great feeling to hear the tractor start again and purr like a cat. I would like to thank all the help I have recieved especially Andy who I bought the kit from. If you have any problems with your distributor on a front mount, I believe going to the electronic ignition is the way to go. If you have any questions, contact Andy (918-274-8000). Again thanks to everyone involved.
GB in MT.
10-01-2007 08:34:11
 Re: Replacing new plug wires in reply to Ricky Kristynik, 10-01-2007 08:22:20
Ricky;
Glad you got it running good again. Thanks for the reply.
Garythird party image
Ricky Kristynik
09-26-2007 10:24:27
Thanks for your input!
Ricky Kristynik
09-26-2007 10:24:19
Brian Bell
09-26-2007 05:48:06
Thanks Gary. I was looking for an old post with your pic in it to put up here for him.
Ricky Kristynik
09-26-2007 07:43:42
 Re: Replacing new plug wires in reply to Brian Bell, 09-26-2007 05:48:06
Thanks for looking!!
GB in MT.
09-26-2007 05:45:21
third party image
This should help for the front mount dist. wiring.
Gary
Ricky Kristynik
09-26-2007 07:40:52
 Re: Replacing new plug wires in reply to GB in MT., 09-26-2007 05:45:21
Thanks alot!! I really appreciate the help!!
