@@###!!!%^****oil fill tube
ricko700
09-30-2007 15:03:26
Is there another type oil fill tube that will take more than 1 qt per day without slopping erl all over my 8n?
john hunt
10-01-2007 05:57:33
 Re: @@###!!!%^****oil fill tube in reply to ricko700, 09-30-2007 15:03:26
caution please " check for frezee plug or blockage in the tube and it hard to see too" oil should fly right in ... you might have to pull the oil pan to remove it too.. some kid might have play the old build compression trick on you too . are like me, some old man got his son up put a frezee plug in my tractor. his thinking was that i wouldn't not be able to fix i would sell for a few hundred dollar..
and other hand you got piece metal got broke away inside of filler tube and cause the blockage too ..
joe in wilkinson
09-30-2007 15:53:52
Try removing the dipstick while filling. It doesn't make sense, but it makes a big difference on my 8N. I suppose it vents. Joe
Tool Kat
09-30-2007 18:42:58
 Re: @@###!!!%^****oil fill tube in reply to joe in wilkinson, 09-30-2007 15:53:52
My 8n has a farmerized addition of an oil tube sweated into another oil tube. Maybe this is why.
Tool Kat
