Override coupler - is this the right one for me?
Britcheflee
09-30-2007 19:10:33
OK,
I am about to order a pto override coupler for my brush hog - I would like your advice if I am ordering the right one for me.
The pto output shaft on the tractor is 1 1/8 - the female end on the drive shaft of the brush hog is 1 3/8
This is what I am looking at ordering:
Link
It was a rather exciting afternoon getting the brush hog out of the back of my brother in laws truck - it went in in moments with the help of a big John deer tractor with a front loader and chain - getting it out involved cables, chains, the winch on the front of my old truck and a lot of scary moments....it is safely out now and we both have all our limbs - want to give it a go but going to wait for the override coupler. Any additional advice about putting these on, use etc would also be appreciated.
Lee
Hobo,NC
10-01-2007 04:38:09
 Re: Override coupler - is this the right one for me? in reply to Britcheflee, 09-30-2007 19:10:33
More than likely you will have to shorten the PTO shaft to make room for the ORC. Slide the shaft apart and cut equal amounts off both ends.
Lets say it needs to B 4" shorter, cut 2" off each shaft.
Third Party Image
MikeT
10-01-2007 03:25:42
Are there any couplers that have an easy-on/off coupling? I'd like to take mine off occasionally but it darn near tood a sledge hammer to drive that pin in.
dlplost
09-30-2007 19:25:34
YES, that should be the correct one.
To install, most have either 1 or 2 grease fittings on them, there also is a pin, remove both grease fittings, rotate the insides till the holes line up all the way thru. Slide it on the pto and line up the hole with the one on the pto, put the pin thru the hole and center it in the coupler (may need hammer and drift punch), put the grease fittings back on then grease it.
Britcheflee
09-30-2007 20:37:26
 Re: Override coupler - is this the right one for me? in reply to dlplost, 09-30-2007 19:25:34
OK, thanks!
Lee
