Order Ford 8N Parts Online
Electronic Ignition for 8N with front mount distributor
Ricky Kristynik
10-01-2007 10:20:20
I put on the new electronic ignition and changed the plugs. What a great feeling to hear the tractor start again and purr like a cat. I would like to thank all the help I have recieved especially Andy who I bought the kit from. If you have any problems with your distributor on a front mount, I believe going to the electronic ignition is the way to go. If you have any questions, contact Andy (918-274-8000). Again thanks to everyone involved.
8N1949
10-01-2007 17:51:43
 Re: Electronic Ignition for 8N with front mount distributor in reply to Ricky Kristynik, 10-01-2007 10:20:20
Ricky, I'm glad to hear you made the choice to go 12 volts with electronic ignition. When I gave you Andy's phone number for you to contact, didn't know it would create some stir of competition.
I made the switch in 2003 after some serious consideration to go 12 volts. I'm glad I did, as it eliminates the old 6 volt coil and pints, which always been a headache to get "just" right.
Now I don't have to worry about the..imfamous coil, points, failing to start on a cold day, or driving several hundred miles trying to locate a 6 volt battery that will fit. There are many more advantages to switch...
Ricky Kristynik
10-02-2007 05:27:51
 Re: Electronic Ignition for 8N with front mount distributor in reply to 8N1949, 10-01-2007 17:51:43
Thanks for your help and Andy was a lot of help. Again thanks!!
JimSC
10-01-2007 17:33:43
Back to the basic question: Do you know for sure it helped? It seems to me when things are right with my front mount, nothing could help it...purrs like a kitten...works like 20 mules. Is it longer lasting? Makes you feel better? Less maintenance? What? I have thought about doing it but need a good reason.
Ricky Kristynik
10-02-2007 05:25:46
 Re: Electronic Ignition for 8N with front mount distributor in reply to JimSC, 10-01-2007 17:33:43
All I know right now is it started right away and runs good. I will try to test it as far as getting hot when we shred with it. I have spent a lot of money on the old system and had a lot of headaches. So far so good. Thanks!!
Bruce (VA)
10-01-2007 12:17:02
 What did you do about the coil problem? in reply to Ricky Kristynik, 10-01-2007 10:20:20
If I recall your previous post correctly, you were burning up 12v coils. Did you replace the square coil w/ a 12v round coil?
Ricky Kristynik
10-02-2007 05:29:24
 Re: What did you do about the coil problem? in reply to Bruce (VA), 10-01-2007 12:17:02
Yes I used the round coil that came with the kit. Again thanks for your help.
Ricky Kristynik
10-01-2007 12:00:24
I was given this phone number on this site. I apologize if I didn't something wrong. Sorry!
Bob
10-01-2007 10:37:48
Don't you think it's a bit rude to post the competition's phone number on this site?
YT, our gracious host, sells the same kit.
TennesseeMan
10-01-2007 16:49:37
 Re: Electronic Ignition for 8N with front mount distributor in reply to Bob, 10-01-2007 10:37:48
Rude? Good Grief!! That's like saying you can't mention John Deere on this 8N site. Afterall people can choose to buy their parts wherever they want.
Bob
10-02-2007 07:47:01
 Re: Electronic Ignition for 8N with front mount distributor in reply to TennesseeMan, 10-01-2007 16:49:37
I REALLY appreciate THIS site, PAID FOR by our hosts, who sell tractor parts.
It just seems "out of place" to steer folks somewhere else, for the same parts that are sold here.
don b
10-01-2007 11:41:58
Bob...I think he is referring to Andy at Genesee,which probably is where YT get's their kits.
Andy helps lots of folks get their EI installed. don b
Bob
10-02-2007 07:47:51
 Re: Electronic Ignition for 8N with front mount distributor in reply to don b, 10-01-2007 11:41:58
Is not not true that this site AND the "other" folks BOTH sell the same Pertronix kits???
don b
10-02-2007 08:29:06
 Re: Electronic Ignition for 8N with front mount distributor in reply to Bob, 10-02-2007 07:47:51
Bob....sorry,I don't understand your question.Run it by one more time. don b
Bob
10-02-2007 08:47:21
 Re: Electronic Ignition for 8N with front mount distributor in reply to don b, 10-02-2007 08:29:06
My point was, since the same kits are sold HERE, folks don't need to be "steered" to another site to buy them.
don b
10-03-2007 11:32:41
 Re: Electronic Ignition for 8N with front mount distributor in reply to Bob, 10-02-2007 08:47:21
Bob...I agree with you on that.I think he was just bragging about all the help he got from Andy,not trying to steer others to buy from them. don b
