Order Ford 9N Parts Online
Wanted 9N reverse idler gear
Sean (TX)
10-02-2007 15:15:34
Also need part # 26. Idle gear is part #24
third party image
third party image
Sean (TX)
10-03-2007 14:09:30
 Re: Wanted 9N reverse idler gear in reply to keithr, 10-02-2007 15:15:34
GB in MT. said: (quoted from post at 06:33:08 10/03/07)
So..... Depending on your work load, you may be be starting to put it back together next week-end!!!!????
Man, it's really raining here this A.M.. I guess another day painting for me, Shot in the butt!!
Have a good day SEAN.
Garythird party image
Wont have all the parts till the following weekend. This weekend Im going to drop the pump and clean all the crap out of the belly. To much sludge...Easy cleaning with it split open. So yup... The weekend of the 20th and 21st ill put it back together. Dont complain you need rain up there!!! The fire out yet???
Ill get some more pics before I put it back together...
Sean (TX)
10-03-2007 14:01:13
 Re: Wanted 9N reverse idler gear in reply to Dave (Tx), 10-02-2007 15:15:34
Michael Tx said: (quoted from post at 20:10:33 10/02/07) Sean
Good luck with your transmission. If you need or want to pour a cement pad to do your tractor work on I have a cement mixer I'll give you. I live in Bergheim Texas which should be fairly close to you. Email me if you want it.
Email sent..
Sean (TX)
10-03-2007 02:42:01
 Re: Wanted 9N reverse idler gear in reply to DON TX, 10-02-2007 15:15:34
Tex - Driftwood said: (quoted from post at 23:10:18 10/02/07) i guess you cant order that part online? I wonder if that guy on 32 has one laying around?
Those part are NLA. John Smith had everything I needed. Should be in the mail today. Now that I found those parts im going to order the rebuild kit.
GB in MT.
10-03-2007 03:33:08
 Re: Wanted 9N reverse idler gear in reply to Sean (TX), 10-03-2007 02:42:01
Tex - Driftwood
10-02-2007 20:10:18
 Re: Wanted 9N reverse idler gear in reply to Sean (TX), 10-02-2007 15:15:34
Dunk
10-02-2007 17:28:28
 Re: Wanted 9N reverse idler gear in reply to Joe (IN), 10-02-2007 15:15:34
Sean (TX) said: (quoted from post at 20:47:02 10/02/07)
Dunk said: (quoted from post at 19:26:54 10/02/07) Not many folks would have owned up to that.
Some high caliber folks here...
I like most all of them!!
I didnt cut it most have been the previous owner. I been running it hard for over a year. Took that shaft a while to walk out of the gear...
So now you are denying it, and I am gonna have to take all that back?!?!?
I don't think so.
Thank God for John Smith!!
Michael Tx
10-02-2007 17:10:33
Sean Good luck with your transmission. If you need or want to pour a cement pad to do your tractor work on I have a cement mixer I'll give you. I live in Bergheim Texas which should be fairly close to you. Email me if you want it.
Sean (TX)
10-02-2007 16:50:45
 Re: Wanted 9N reverse idler gear in reply to Dunk, 10-02-2007 15:15:34
John Smith had the parts on hand...Problem solved..
Sean (TX)
10-02-2007 16:47:02
 Re: Wanted 9N reverse idler gear in reply to Tom N MS, 10-02-2007 15:15:34
Sean (TX)
10-02-2007 16:45:31
 Re: Wanted 9N reverse idler gear in reply to Steve IA, 10-02-2007 15:15:34
Found it in the spam filter John...Put you on the approved sender list.
Sean (TX)
10-02-2007 16:12:40
 Re: Wanted 9N reverse idler gear in reply to Sid, 10-02-2007 15:15:34
John Smith has a pin. Have not heard back from him, Sent him email. Still looking for a good used gear. Its a NLA pin and gear. When I get one I can send you the old cut off one and the right length. Be good enfo to keep on hand. Ill bet this is not the first time this has happenend!!
Pulling yours out would be easy. The hard part is getting it back in. (DONT DO IT!!!) If that gear or pin moves at all you cant get the pin back in.. You cant get at it from the top. You will have to split your tractor in 3. Not a easy project. That gear and shaft is on the bottom of the transmission. That bolt in pin is on the out side of the transsmission. People have posted here before and made the mistake of pulling the pin and wondering how to get it back in. Some think it is how you check the tranny oil level...NOT third party image
TheOldHokie
10-02-2007 16:54:04
 Re: Wanted 9N reverse idler gear in reply to Sean (TX), 10-02-2007 16:12:40
Some dufus did a similar thing 15+ years ago to my T-bird - now who could that have been? Cost me $350 to get an emergency reattachment at a local transmission shop.
TOH
John Smith8N
10-02-2007 16:33:21
I've got a good pin right here with your name on it. Email must not be getting through. If you have a way of checking your deleted spam emails take a look in there. I've got the idler gear, too.
TheOldHokie
10-02-2007 15:44:07
Sean,
If you cant find one give me yell. Looks pretty simple - I can likely make you one if I you can get me decent dimensions. If not I might be able to pull the one in my 9N - how hard is it to get back in if you have the ccver off?
TOH
Sean (TX)
10-02-2007 15:37:07
 Re: Wanted 9N reverse idler gear in reply to JerryS, 10-02-2007 15:15:34
Just pulled the old pin to see it for myself. Someone pulled the pin....The common mistake...I thought it was to check the fluid level third party image third party image
Couldnt get it back in and cut it off with a hack saw third party image Then put the pin back in... I have at this tractor since june of 2006. Took the pin a while to work its way out of the gear...
Hard to see but this is what is left of the pin.
third party image
Dunk
10-02-2007 16:26:54
 Re: Wanted 9N reverse idler gear in reply to Sean (TX), 10-02-2007 15:37:07
