oil pump question?
hndymann22
10-05-2007 08:48:29
I was getting ready to order oil pump repair kit, and it was giving me 2 measurements for the gear. Ok since I am learning on this, is it the big ft. gear they are wanting the measurment on. Or the width of the gears inside of the pump? I know it is a noob question, but want to order the right part the first time....lol..
9NJoe
10-05-2007 13:28:27
 Dayum!! in reply to hndymann22, 10-05-2007 08:48:29
Handyman,
I feel yer pain. What you want it the THICKNESS of the gear not the diameter. All pump housings are the same size so they take the same diameter gears, its the height of the gears that come in two flavors.
Joe
Dell (WA)
10-05-2007 09:36:37
 Re: oil pump question? in reply to hndymann22, 10-05-2007 08:48:29
un-handyman..... ....iff'n the oilpump gear didn't have teeth, it would be a cylinder. What would you measure??? DIAMETER and height. Would you believe the oilpump kits are asking for DIAMETER??? Would you believe it is not a micrometer measurement??? Can you tell the difference between 9/16" and 3/4"???..... ..respectfully, Dell
hndymann22
10-05-2007 09:52:02
 Re: oil pump question? in reply to Dell (WA), 10-05-2007 09:36:37
(3) If your oil pump gear is 34 or 916 inches wide. That is what they are asking for, and I was asking which gear? (I thought they were asking how thick the gear were) The main ft. gear, or the inner gears. Didnt think I was that stupied, but I guess my question was... Thank you dell for your answer....
don b
10-05-2007 10:57:59
 Re: oil pump question? in reply to hndymann22, 10-05-2007 09:52:02
The gears are measured by their thickness not diameter. don b
Hobo,NC
10-05-2007 09:50:31
That would B the wiff/thickness, DIAMETER izz the same I use a wranch
