clutch
ricko700
10-05-2007 20:25:09
I just did an overhaul on my 8n and it included a new clutch disk now I push the pedal almost (1") from the running board before I feel any resistance at all...nothing really changed much..the old disc wasnt worn too badly..whats the deal?
Ross Pugh(NC)
10-06-2007 07:59:42
 Re: clutch in reply to ricko700, 10-05-2007 20:25:09
Open the FO-4 manual to page 64 and follow those directions as that is the only clutch adjustment there is.
Dave H
10-06-2007 05:47:09
I am sure you made sure you put the clutch disc in facing the correct way?
ricko700
10-06-2007 06:54:58
 Re: clutch in reply to Dave H, 10-06-2007 05:47:09
I put it in with the long end of the spindle facing the rear of the tractor..thats right isnt it..it didnt look like there was enough room the other way??
Dave H
10-06-2007 16:29:21
 Re: clutch in reply to ricko700, 10-06-2007 06:54:58
yep, you faced the disk right
ricko700
10-06-2007 17:17:21
 Re: clutch in reply to Dave H, 10-06-2007 16:29:21
Whew!! Thanks.
Bob
10-06-2007 08:19:06
If you have to split it again, use this gauge to see where the release finger "heights" are as compared to where they're supposed to be.
If the replacement lined plate is excessively THICK, the finger heights will be too "low", and the reasle bearing will have to move too far (low pedal", before contacting them.
Third Party Image
