Order Ford 8N Parts Online
8n pix
ricko700
10-07-2007 17:45:46
third party image
Purdyyyyy yy!
Hobo,NC
10-07-2007 18:53:31
 Re: 8n pix in reply to ricko700, 10-07-2007 17:45:46
Once you have the block assembled install the head with out a gasket, use a few head bots just to align the head up DON"t run"em down. Not rotate the engine 1 turn if the piston tries and lift the head you mite not think it looks so "Purdyyyyy yy!"
Deck"n a n block and cut"n the head mite cause piston to head interference, if you run into that post back with the head pix and i will tell ya how to fix it.
ricko700
10-07-2007 19:06:15
 Re: 8n pix in reply to Hobo,NC, 10-07-2007 18:53:31
I already checked it before I put in the studs..without the gasket and turned the crank pulley nut with a BAW whilst I was crouched down like a puma with the evil eye and turned it over several times..my machinist told me to be sure nothing moved while I was doing that...what would u do to fix it if there was a problem??
GB in MT.
10-07-2007 18:22:40
Ricko; NOW what you need to do is: go back to photo bucket, and set the size of your pictures to 640x480. That way your pix won't take so much room to download to the message board screen.
Just trying to help ya.third party image Nice clear pic. though.
Garythird party image
Dunk
10-07-2007 19:20:56
 Re: 8n pix in reply to GB in MT., 10-07-2007 18:22:40
Dayum, Gary!!
After he asked that I went and looked, couldn't find it!!
I found it now!!! Thanks!!!
Mine are set for 800 x 600, but I don't have any that big.
GB in MT.
10-07-2007 19:34:42
 Re: 8n pix in reply to Dunk, 10-07-2007 19:20:56
I can't remember who it was that pointed that out to me.
It was someone on here, but it sure helps not to have to move the screen out to see all of the pix. Not to mention, it helps the guys on Dial-up, for shorter download time.third party image
Did I just say all that!!!! third party image
Gary third party image
ricko700
10-07-2007 18:35:49
Do u need to do it one pic at a time or can I resize all of em at once?
GB in MT.
10-07-2007 19:09:57
 Re: 8n pix in reply to ricko700, 10-07-2007 18:35:49
Ricko; when you get to P-Bucket, go to your album, just be low where the download area is, you will see a light sentence that says max. image size.
click on options and mark the dot next to 640x480. That should change all your uploads and pix in your album, and any future pix will be that size.
ricko700
10-07-2007 18:32:24
ok thanx
Dunk
10-07-2007 18:05:40
It would be nicer to the others if you could keep them all in one topic though.
ricko700
10-07-2007 18:07:20
 Re: 8n pix in reply to Dunk, 10-07-2007 18:05:40
Yeah I know Ill work on it..Ive seen lots of guys doing 5-6 pix on one post?
Dunk
10-07-2007 17:57:05
I've created a monster!!!
Just kidding!!
New head?
ricko700
10-07-2007 18:06:02
 Re: 8n pix in reply to Dunk, 10-07-2007 17:57:05
LOL...not new just ground and primed ..the block got a deck job and the crank got turned all for 140 bux, hope I can remember how to post pix tomorrow..lol
Tom N MS
10-07-2007 18:32:06
 Re: 8n pix in reply to ricko700, 10-07-2007 18:06:02
You got a really good deal.
