Order Ford 8N Parts Online
8N lift week
Pete(OK)
10-08-2007 19:07:22
1948 8 N lift is week any ideas??what kind of fluid does it take?
soundguy
10-09-2007 06:53:02
 Re: 8N lift week in reply to Pete(OK), 10-08-2007 19:07:22
As tom and the others are telling you.. Do verify the leaky area before you tear into it.. otherwise it will be hard and expensive to chase down.
soundguy
ZANE
10-09-2007 05:24:37
CLICK ON THE LINK BELOW FOR A REALLY GOOD WEB PAGE FOR TROUBLE SHOOTING THE 8N.
SMITH'S 8N PAGE
Sean (TX)
10-09-2007 03:09:03
 Re: 8N lift week in reply to OKDAD, 10-08-2007 19:07:22
Roughly 5 gallons. You can get it at TSC or NAPA. GL1
Pete(OK)
10-08-2007 20:00:49
Ok i'll give it a try. How much does it hold and where do I get it?
GA Dave
10-08-2007 19:56:05
What's wrong with the 90 wt from Ortazone or O'Really's? David.
Den N Ms
10-08-2007 19:55:23
Pete,You have the wrong fluid in it.Ya need GL1 fluid 90 weight.
Tom N MS
10-08-2007 19:32:13
90WT G-L-1...Did it just get weak or has it always been weak? Weak meaning it will only lift 200 lbs? or does weak mean it lifts slow? More details please.
Pete(OK)
10-08-2007 19:43:51
 Re: 8N lift week in reply to Tom N MS, 10-08-2007 19:32:13
been weak for long time.thought I would change the relief valve.I changed the oil but I used trans-hrydo fluid.
Tom N MS
10-08-2007 19:59:11
 Re: 8N lift week in reply to Pete(OK), 10-08-2007 19:43:51
What do you mean by "weak"? Is it slow? It won't lift heavy loads? Does it leak down?
Pete(OK)
10-08-2007 20:05:35
 Re: 8N lift week in reply to Tom N MS, 10-08-2007 19:59:11
Lifts a small angle blade about an inch or 2.It will lift arms with no load.
Tom N MS
10-09-2007 03:54:10
 Re: 8N lift week in reply to Pete(OK), 10-08-2007 20:05:35
Remove the side cover at your right heel where the dipstick is located. While lifting the blade, look inside with a flashlught to see if you see oil leaking from above(leaking from the cylinder).
If you see oil streaming down from the top you most likely need to revuild the cylinder. Also look down in the oil in the bottom of the pump to see if you notice excess turbulence(you will see some oil movement because of the PTO shaft turning). If you see a lot of turbulence, you likely have a leaking safety valve. WITH TRACTOR OFF, reach in and locate the safety valve, just below the PTO shaft. Remove your hands from inside the tractor pump area and crank the tractor. Engage the PTO and lift the blade as high as it will go. Reach in and feel the end of the Safety valve. You should feel no Pressure. If it tries to push your finger off of the end, then the SV is bad and needs replaced. Check these things and post back. Hope this helps.
Pete(OK)
10-09-2007 12:12:26
 Re: 8N lift week in reply to Tom N MS, 10-09-2007 03:54:10
Thanks for all the info.The guys at the part stores are no help at all.
