front mount distributor
ricko700
10-09-2007 15:43:53
As yer lookin at the front of the tractor there is a screw ,,hex head slotted I tink... sticking out the right side of base..by the clip..whats that for?
8N1949
10-09-2007 16:07:46
 Re: front mount distributor in reply to ricko700, 10-09-2007 15:43:53
That is your Timing plate and locking screw. You have six marks on the side of the distributor. Three upper and three lower from center of the screw and plate. This adjustment is made after your have installed the distributor and cap, by moving the screw and plate up to advance or down to retard the timing.
JMOR
10-09-2007 19:17:18
 Re: front mount distributor in reply to 8N1949, 10-09-2007 16:07:46
THINK YOU GOT THAT UP/DOWN, ADV/RETARD BASS AKWARDS.
p.s. YOU NEED TO REMEMBER, THESE POSTS ARE TO MAKE YOU THINK....NOT TO BE TAKEN AT FACE VALUE!
36 coupe
10-09-2007 16:07:14
Timing is adjusted there .Leave it alone.
