Steering Lubrication
Rush-N
10-10-2007 06:09:42
third party image
I have a 1948 8N with a later style steering set-up. I replaced the sector seals and want to install a grease fitting in the correct location to properly lube the steering gears. Looking at the pictures, which side is the correct location to install the Bolt/Grease Fitting? Also do most of you keep a grease zerk fitting in the steering column?
Thanks, Rush :)
soundguy
10-10-2007 08:26:28
 Re: Steering Lubrication in reply to Rush-N, 10-10-2007 06:09:42
Yep.. right side where it will almost interfere with proofmeter cable.. etc.
A hollow/drilled out 7/16 ( i think! ) bolt with a greese fititng installed inthe head will work.
Soundguy
Rush-N
10-10-2007 06:13:23
third party image
Steering Column
Thanks, for all your help. Rush :)
Rush-N
10-10-2007 06:11:12
third party image
Drivers side of Tractor...
