Order Ford 8N Parts Online
8 volt Battery in 8n tractor
Pack46
10-10-2007 10:08:41
People: I put an 8 volt battery in my 49 8N, my volt meter shows neither charge or discharge, but I cannot polarize my Regulator or at least I get no sparking when I try to polarize it. Can someone out their tell me what I"am doing wrong.
gahorN
10-10-2007 12:51:44
 Re: 8 volt Battery in 8n tractor in reply to Pack46, 10-10-2007 10:08:41
You can keep your 8-volt battery and it will work just fine.
All you have to do is:
Change your 6-volt generator to an 8-10 volt unit.
Change your 6-volt regulator (if any) to an 8-10 volt unit.
Change your ignition coil to an 8-volt unit.
Change all your lights to 8-volt units.
Change any non-mechanical gauges to 8 volt units.
Otherwise, if it doesn't bother you too much to keep your money in your possession, you could just swap that fantastic 8-volt battery for a sorry utilitarian 6-volt unit. third party image
soundguy
10-10-2007 11:35:32
As the others are telling you.. you have just put a square peg into a round hole and are having problems.. and you are wondering why?
Also.. do you really have a volt meter.. or do you have an ammeter like these tractors had when they were new?
get a 6v battery then fix the problems that made you think you needed the 8v bandaid battery.
post back.. we'll help ya.
Soundguy
Colin King
10-10-2007 10:24:12
Pack,
Your 6volt charging system cannot charge an 8volt battery. Get yourself a 6volt battery.
To polarize, briefly touch the BAT/ARM terminals on your VR.
Colin, MN
Too Tall
10-10-2007 10:23:20
Why did you put in an 8V battery?
