Order Ford 8N Parts Online
1951 8N progress report.,#2
old
10-10-2007 17:02:30
Well I have the new/used valve/guide in, head on again, torqued and retorqued when it was warmed up. Checked compression and all cylinders are 130 plus PSI. Now for all the fun stuff, the stuff that takes forever to get done. I have to make an alternator mount, rewire it, put on lift arms for the 3 point, etc ,etc ,etc. Also will need to install a fan belt because the way this on is you can't do it after the front alxe is on it.
Ken(Ark)
10-10-2007 19:00:49
 Re: 1951 8N progress report.,#2 in reply to old, 10-10-2007 17:02:30
I read somewhere that for every ten hours of use that you can expect one hour of maintenance .
I guess the true definition of mission creep would be for every one hour of use you can do ten hours of mechanicing . I am glad these old tractors are so much fun to work on , he he .
Glad to hear you just about have it going - Ken(Ark)
