2n radiator
orval
10-14-2007 14:38:20
started going into this old tractor. pulled the hood off and the only thing holding the radiator on was the hoses. no shroud. is this right?
Dunk
10-14-2007 15:12:31
 Re: 2n radiator in reply to orval, 10-14-2007 14:38:20
Mine has not had a shroud in our 25 years together, it has 2 bolts on the bottom, and the hoses.
Bruce (VA)
10-14-2007 15:11:55
And it had a fan shroud. It's needed to move air over the entire radiator for proper cooling. (tip # 35, below)
old
10-14-2007 14:56:44
Should have 2 bolts that hold it down at the bottom of it. Some one may have left them off. There a carrage type bolt 7/16 and about an inch long. The heads of the bolts slide into a slot on the bottom
Bob
10-14-2007 14:47:03
There's also supposed to be a "horsehair" pad around the radiator neck, that also stabilizes the radiator a bit.
