oil pressure line
ricko700
10-17-2007 14:27:37
Does the line to the oil pressure gauge need to be filled with oil for the gauge to work..I just put on a new line after rebuilding the motor and want to check to see if I have oil pressure before the electrified start?
soundguy
10-17-2007 14:35:03
 Re: oil pressure line in reply to ricko700, 10-17-2007 14:27:37
technically the air pressure would produce a reading 9 pressure is pressure ).. however since air compresses and changes density with temps.. it would be a bouncy eratic #.
Leave the fitting loose with a rag arounf it and fire it up.. it will self purge and rust proof the back of the dash helping to preserve it!
( worked for me.. )
soundguy
Lance in Brenham, TX
10-17-2007 14:31:49
Yes - that's what I did. It worked for me. Seems like if you don't fill it, you'll just have air pressure, not hydraulic, which is what's needed for a correct reading.
gahorN
10-17-2007 14:40:48
 Re: oil pressure line in reply to Lance in Brenham, TX, 10-17-2007 14:31:49
Actually the reverse is true. Air is compressible and will dampen the gauge.
