Shifter boot - any grease underneath?
elcidd
10-17-2007 21:14:02
I just installed a new shifter boot on my 9N, and now I'm wondering if I should have put some grease underneath the boot? Thinking maybe it would help keep moisture out if it gets into the new boot. What do you do when installing a new one?
Installation tip: I used a heat gun to soften up the new boot. Works much like boiling. It's amazing how little these things stretch before you heat them up.
third party image
elcidd
10-18-2007 09:10:48
 Re: Shifter boot - any grease underneath? in reply to Den N Ms, 10-17-2007 21:14:02
gahorN said: (quoted from post at 10:39:48 10/18/07) I don't remember which Ford N site debunked this problem with tests with/without boots and proved that water does NOT get into the tranny via a bad boot. Does anyone else recall this article?
That's interesting, I'm new to old tractors but I thought the leaky boot problem was a proven fact. I'm going to check for that article.
Sounds like I wasted my hate on that little boot for nothing! third party image
gahorN
10-18-2007 08:39:48
 Re: Shifter boot - any grease underneath? in reply to elcidd, 10-17-2007 21:14:02
Danny in CO
10-18-2007 08:58:24
 Re: Shifter boot - any grease underneath? in reply to gahorN, 10-18-2007 08:39:48
John Smith did the tests you are talking about. He probably has them on his site.
Danny
gahorN
10-18-2007 09:59:13
 Re: Shifter boot - any grease underneath? in reply to Danny in CO, 10-18-2007 08:58:24
Danny in CO said: (quoted from post at 08:58:24 10/18/07) John Smith did the tests you are talking about. He probably has them on his site.
Danny
Nope. That's not where it is. third party image
Danny in CO
10-18-2007 13:28:38
 Re: Shifter boot - any grease underneath? in reply to gahorN, 10-18-2007 09:59:13
Here is the link to John's results:
Hobo,NC
10-18-2007 16:11:44
 Re: Shifter boot - any grease underneath? in reply to Danny in CO, 10-18-2007 13:28:38
2 cure the water from git"n into the draft spring flip the seat over backerds, instant umbrella
TheOldHokie
10-18-2007 10:02:56
gahorN said: (quoted from post at 09:59:13 10/18/07)
Danny
Nope. That's not where it is. :(
It was posted on the "other" N tractor club forum.
TOH
elcidd
10-18-2007 08:00:57
 Re: Shifter boot - any grease underneath? in reply to diverjeff, 10-17-2007 21:14:02
Britcheflee said: (quoted from post at 00:26:15 10/18/07) I put grease under my 8N boot - thought the same thing as you - would help keep water out. I agree about getting that boot on.....I eventually used two of those devices you get from the paint store for opening cans of paint, the hooked end assisted in pulling it out and down.....
Various crass analogies sprung to mind when trying to describe getting that thing on....
Lee
My first mistake is that I didn't check on this board before I tried installing the new boot. I bought mine at a local farm supply store and before I left the store I did think to ask the salesman if there was any trick to installing it. "Nah, it just slips right on." is what he told me. third party image
I hurried home to replace my cracked boot as there was a rain storm coming and it wasn't too long before I decided the salesman was no friend of mine, lol. I did manage to get it on the shaft, but the lower part wasn't going on no matter how much I tried/cursed. I checked here and the boiling water trick sounded good but I didn't want to try to get the boot off again. That's when I thought of the heat gun. third party image Who knew such a harmless looking rubber boot could cause such trouble, lol.
Colin King
10-18-2007 08:12:06
 Re: Shifter boot - any grease underneath? in reply to elcidd, 10-18-2007 08:00:57
LOL. Trouble. I'll say. I first made my attempt when it was 10 below zero. Not fun.
Colin, MN
D squared
10-18-2007 02:20:20
A blue 3 speed? I think you are off a couple of series. I don't currently need a boot, but when I do I will grease the shifter.
Britcheflee
10-17-2007 22:26:15
Lee
