Order Ford 9N Parts Online
9n sector shafts
BRIAN MN
10-21-2007 10:19:46
BOUGHT NEW SECTORS SHAFTS AND BOTH RIGHT AND LEFT SHAFTS HAVE THE SAME TOOTH ANGLE. Need to be opposite angles to fit the worm gear.Dealer says they should be correct. They haven"t heard from anybody else with problems. Can somebody help me?
Joe T (CO)
10-21-2007 21:47:03
 Re: 9n sector shafts in reply to TheOldHokie, 10-21-2007 10:19:46
BRIAN MN said: (quoted from post at 03:54:11 10/22/07) The dealer doesn't understand why the teeth are supposed to be opposite directions
Is it possible you have two rights or two lefts?
Show the dealer this, it explains why....
third party image
soundguy
10-21-2007 16:49:54
 Re: 9n sector shafts in reply to BRIAN MN, 10-21-2007 10:19:46
Ya might try hosting thos pics where we all can see them!
soundguy
BRIAN MN
10-21-2007 19:54:11
 Re: 9n sector shafts in reply to soundguy, 10-21-2007 16:49:54
RP-40-9n
10-21-2007 14:06:53
brian, if you compare the new sectors to the old and they are not right, then take the new ones back along with the old ones and get the ones you need. when you look at the old ones its plain to see the teeth are different angles, left to right and if the new ones dont match they cant work. RP
Tom N MS
10-21-2007 11:26:57
Link says cannot display the page.
