starter issues
ricko700
10-21-2007 11:46:54
My starter worked fine before I er uh didnt read the post about not letting the brushes pop out. I put it all back together 2 or 3 times and just did it again...all the brushes are in rite and the bare wires are not touching anything other than the brush and where they attach to the case and the insulated wires are as far from the case as I can get em...how do I bench test it now??
OKDAD
10-21-2007 14:03:16
 Re: starter issues in reply to GB in MT., 10-21-2007 11:46:54
I should clairfy to look for a broken/burned through wire on the field wiring, brushes, and to the post.
OKDAD
10-21-2007 13:56:24
 Re: starter issues in reply to corvetteguy, 10-21-2007 11:46:54
So the next thing I would do is pull the armature out and check carefully for a broken wire. If you don't find one then it is probably time to take it to your local starter repairman.
OKDAD
10-21-2007 13:49:04
 Re: starter issues in reply to russb, 10-21-2007 11:46:54
That makes sense as the solenoid is just a relay. Are you sure the brushes are riding on the armature?
ricko700
10-21-2007 13:52:06
 Re: starter issues in reply to OKDAD, 10-21-2007 13:49:04
I checked by pushing them down with a screw driver to see if it made the armature harder to turn on each one,,and it did..I did turn one brush around as it looked like the 2 wires were crossed and none of the other 3 were crossed.
OKDAD
10-21-2007 13:32:40
 Re: starter issues in reply to Wasgd4u, 10-21-2007 11:46:54
ricko700 said: (quoted from post at 14:12:14 10/21/07) By the way ..where in OK are you..I have 40 acres in Seminole County.
Ricko....Far South OKC where I have 5 acres.
From the other post it sounds like you connected it to a battery via jumper cables and got nothing. That means something inside is not right. Take it back apart and look it over closely.
Ike
ricko700
10-21-2007 13:39:43
 Re: starter issues in reply to OKDAD, 10-21-2007 13:32:40
When I had it hooked up to the tractor at least the solenoid was clicking ...now ZIP!!
OKDAD
10-21-2007 11:57:49
 Re: starter issues in reply to Dan, 10-21-2007 11:46:54
Ricko,
Get some jumper cables, connect one end to your battery then connect one to the starter frame (mounting bolt sticking out held by nut....right?) and touch the other to the copper terminal while holding the starter with your foot, vice, sitting on it, etc. You will get a spark and it should jump and spin.
If all you get is a spark with no spin you still have a problem. Look again for shorts.
Ike
ricko700
10-21-2007 12:12:14
 Re: starter issues in reply to OKDAD, 10-21-2007 11:57:49
ricko700
10-21-2007 12:09:41
Ok hook up cables to battery..clamp one(+) to the stud on starter and the other(-) to the copper on the solenoid side or the stud on the starter?
