Flywheel
Sean (TX)
10-22-2007 15:05:42
How far can they be turned? Has a couple of nicks and scratch. Im guessing they are like a brake rotor and can be turned only so far? Got the broken bolt out of the flywheel today. Going to take it to the machine shop in the morning..
third party image
Baling wire good enough to use on the bolts that hold the flywheel to the crank? got rained on last night...Windy and blew my tarp off...
third party image
Sean (TX)
10-23-2007 15:28:55
 Re: Flywheel in reply to soundguy, 10-22-2007 15:05:42
Thanks Don...Should I take a caliper with me and check it before I pay them? They asked me the year make and model...WOW LOL thats older then me she said...Me to thank goodness...Disk looked pretty good except for all the miner oil it had been drinking. Ill bet it has not been turned in a clutch job or two or three. It was worn for sure but what can you expect after 66 years.... I just cant see not having it resurfaced and puting a new clutch in...
don b
10-23-2007 06:36:55
 Re: Flywheel in reply to Sean (TX), 10-22-2007 15:05:42
Sean.....the minimum thickness of the flywheel should not be less than .855. don b
Sean (TX)
10-22-2007 19:02:00
 Re: Flywheel in reply to Eddy Guerra, 10-22-2007 15:05:42
Thanks Gary...Ill have a look.
GB in MT.
10-22-2007 17:13:29
Sean; I think you need to go to the Hardware store and buy a one lb. roll of 16ga. Mechanics saftey wire, for the flywheel/crank bolts. Dormans products, Inc. Makes this wire just for these types of use. Don't cost much!!!
I use it for all sorts of things. I would not use bailing wire, as it is too soft for this type of application
JMHO
Garythird party imagethird party image
Sean (TX)
10-22-2007 16:38:30
 Re: Flywheel in reply to Ben Rivard, 10-22-2007 15:05:42
Howdy Donn, Had tranny troubles so I rebuilt it. New bearings seals and gaskets. Located a machine shop in San Antonio...36 bucks to resurface the flywheel. Not to bad. I have not had one done in years I think it was 20 bucks back then..
Tom N MS
10-22-2007 16:33:44
I'd hit it 9 swipes with sandpaper and install and run it. I see nothing that would worry me about putting it back together without re-surfacing it. Electric fence wire will do the trick. No pressure on it, it just keeps them from wanting to start backing out. Most likely will never move one milligillionth if you never put wire back in it.
DONN-MI
10-22-2007 16:31:58
Sean, Looks like your into this thing with both feet. The machine shop will surface grind it just enought to clean it up which shouldn't be much unless you have some deep digs in it. Probably no more than 10-15 thousands. It will make the clutch nice and smooth. Donn
TennesseeMan
10-22-2007 15:35:12
I'd get on an aircraft site and find some safety wire. You won't go wrong.
