Order Ford 8N Parts Online
8n IT STARTED
RJ IN WYO
10-22-2007 15:11:02
IT STARTED IT STARTED. I have been working on and off for the last year doing a rebuilt on this tractor. thanks for all your help and advice that help me out. this site cant gbe beat. I have a few little things to do and put on befor i can run her and get her out of the shop. when my dad was alive this was his favorite 8n on the farm. I know he would love this new motor in it if he were here. so befor i take it out is there any info to help me break it in oil changes and things to look for. thanks rj in wyo
LeeMo
10-23-2007 09:06:43
 Re: 8n IT STARTED in reply to RJ IN WYO, 10-22-2007 15:11:02
Congratulations !! Your Dad is probably smiling down at you right now. It looks like you've gotten good advice below so I'll leave it at that.
soundguy
10-23-2007 05:24:16
Ditto what bruce said on the head retorque after warm, not overfilling the rad, and Do turn the gas off.
and yes.. if you have new rings and sleaves. they will take just a bit of time to wear in.
if it continues to be a chimney after you've put a few hours of good hard work on it, do a wet/dry compression test to check the rings / valves..e tc. ( note: a bad oil ring may not show up on a comp test due to good comp rings.. etc.. )
Soundguy
RJ IN WYO
10-22-2007 18:45:55
also forgot to mention that its smoking alot im assuming its because the rings have not seated is that correct rjinwyo
Bruce (VA)
10-22-2007 16:26:16
Congrats! I just love it when a new rebuild starts.
A few things to watch for.....
Keep a close eye on start-up oil pressure.
Retorque the head bolts after you have run it up to operating temp for 30 minutes.
Do not overfill the radiator (tips 24 & 25, below)
Change the oil after an hour or so of run time.
Turn the gas off every time you turn the key off. (tip # 9)
Have fun & check back w/ progress reports & any questions.
TennesseeMan
10-22-2007 15:33:36
Congrats. I'm sure your Dad would be proud. What a beautiful sound when she starts after all the Blood, Sweat and time you have put in. Not too mention the money side of it all.
