Order Ford 8N Parts Online
8N
Richard Kelley
10-25-2007 11:59:53
Point setting. Front mount
Would a bigger or smaller gap give me a hotter spark ?
rich4
10-25-2007 17:59:00
 Re: 8N in reply to Richard Kelley, 10-25-2007 11:59:53
Correct setting is the best way to go, under gap will eventually give starting problems, adjust for the correct gap and timing and you will get good results. Over gap and it may run erratic.
Zeusdog
10-25-2007 16:49:55
You'd have better luck increasing the spark plug gap just a bit.
Jack - Illinois
10-25-2007 16:10:48
Well now according to my brother-in-law that use to work for the Ford dealership back in the '50s, if you was going to try varing off the .015 point setting it was better at .014 than at .016 when he use to put them on the Sun machine and set them by dwell as was really recomended. He messed around with this to find out when he had to got to the farms on trouble calls. But who has a Sun machine anymore that mounts a front mount distritor? The Sun also mounted the double sided front mounts used on the V8 engines.
old
10-25-2007 13:46:47
Changeing the point gap will not help your spark any plus it will throw it out of time just a little bit. Plus it will not run as well either
duey
10-25-2007 12:06:04
You might want to read the BASIC IGNITION post to Britchflee a couple posts down....
duey
Danny in CO
10-25-2007 12:02:30
Nope.
