limit chains
RP-40-9n
10-26-2007 10:11:15
has any of you guys figured a way to alter the limiter chains so as to be better adjusted, one link is about a 2 inch raise or drop and it seems im allways right between where i would like to be? any suggestions please? RP
ZANE
10-26-2007 18:07:24
 Re: limit chains in reply to RP-40-9n, 10-26-2007 10:11:15
If you would install one of my ZANE THANG position control devices on your tractor you could throw the crutches (chains) away.
Click on the link below for information about this and other stuff I make for the Ford tractors.
Zane
8N1949
10-26-2007 18:49:19
 Re: limit chains in reply to ZANE, 10-26-2007 18:07:24
ZANE said: (quoted from post at 18:07:24 10/26/07) If you would install one of my ZANE THANG position control devices on your tractor you could throw the crutches (chains) away.
Zane
ZANE THANG STUFF
What does a ZANE THANG look like.. Photo is a "silent salesman"
Tex - Driftwood
10-26-2007 15:07:31
Hey RP, got any good crops this Fall?? I know all that rain in the early summer messed things up pretty bad for you.
RP-40-9n
10-26-2007 15:15:11
 Re: limit chains in reply to Tex - Driftwood, 10-26-2007 15:07:31
hi tex how ya doin, no i didnt do any fall crops. right now im working on leveling out my ground lumps- humps and shallow areas, and i need mybox blade to just skim the ground. and with the tips from these pros on this forum i think i will be able to giterdun. you doin o k with that new ride of yours? RP
Tex - Driftwood
10-27-2007 07:59:01
 Re: limit chains in reply to RP-40-9n, 10-26-2007 15:15:11
its like night and day! the thing actually runs good.
Marty 2N IL
10-26-2007 12:09:53
I just put a twist in my chains. I do the same on my trailer safty chains so they don't drag.
Hobo,NC
10-26-2007 20:11:11
 Re: limit chains in reply to Marty 2N IL, 10-26-2007 12:09:53
I'm with you Marty BUT if I ever try and lift the Titanic I will make sure I have my chains all lined up.
old
10-26-2007 12:51:32
Marty, did you know a twisted chain is about 10 times more likely to brake and because of that its unsafe to do so. Also if you got pulled over and had that chain twisted on your trailer you might get in trouble for doing so if you got stopped by the right cop. Shoot D.O.T. will make a trucker un hook a chain and rehook it if one of his chains is twisted. Guess ow I know that one LOL
old
10-26-2007 11:54:58
I with Sound on this one a turnbuckle in place of the chain works well and if you can find them they where even some made just for that but I have never found any place that sells them that are made just to fit the N series tractor but at one time they did make them
soundguy
10-26-2007 10:32:05
Add one of those doohickies that screws together or apart like a toplink to shorten or extend.. I've seen em at TSC for chain hookes on each end... hook them across each side of your limit chains and them you have infinite variable adjustment... Can't for the lift of me remember their name right now.... uh.. wait.. here it comes. TURNBUCKLE
Soundguy
