Andy..... ...unless ya been diddlin' with the distributor, timing don't suddenly change. Ruff runnin' at start-up is usually weak sparkies or FLOODED carburetor. You have described FLOODED carb as it cleaned up innna'bout 1-min. This rules out weak sparkies as they don't "fix" themselves, but a flooded carb will (kinda). So because you don't understand, you have thrown a passel of parts unnecessarily and have caused yerself more grief. Now yer guessin' "timing". What else have you done that you're not tellin' us about??? First, PROVE yer sparkies are good. Will they jump a full 3/16" gap??? As a general rule, yer roundcan ignition coil is bullet-proof. Verify yer points gap is still 0.025", new points are known to loose their gap due to invisibly worn adjust screw threads. New SHORT #8x3/16 points screw is only $50c (cheap). Handy tip: Ignition points on occasionally used engines will gitt "invisible contaminates" and cause weak sparkies that can be cleaned by drawing a dollarbill thru the gap and polishing the points. NOT YER PROBLEM. Besides you've already replaced yer points. Based on yer description, yer current NON-START problem is probably still caused by FLOODED sparkies. Replace yer sparkies with NEW CLEAN DRY Autolite 437 sparkies gapped 0.025". DON'T ARGUE, do it!!! Why? 'cuz all yer crankin' has "flooded" yer current sparkies with "invisable" no-lead contaminates. You don't haffta throw yer current flooded sparkies away. They can be cleaned and dried, one-atta-time, in a hot running engine and re-used later..... ....Dell, yer self-appointed sparkie-meister
