Jubilee correction: Can't get hub off.
expansive211
10-27-2007 20:44:31
Forgive me. I meant to say HUB. I can't seem to get the hub off of my Jubilee.
old 9
10-28-2007 16:42:49
 Re: Jubilee correction: Can't get hub off. in reply to expansive211, 10-27-2007 20:44:31
HEAT big torch heat around and hit with one BFH. For satety losen the nuts but do not take them all the way off.
ZANE
10-28-2007 07:17:30
If you arent in a big hurry to get the hub off all you have to do is back the axle nut off a couple of rounds and then go back to using the tractor normally. The hub will work itself loose in a matter of time.
Zane
Steve IA
10-28-2007 03:37:07
I had a hub so tight on my jube I had to remove the brake backing plate bolts and pull the axle (I&T FO-19 shows ya how) so I could get to the back of the hub with a drift and a BFH. I had a wheel puller on it tight and when it released afte a couple of whacks, it flew. Be careful. While the axle is out it's a good time to check the bearings and R&R if necessary. Steve
