Order Ford 8N Parts Online
9n hydralics or 8n??
Mark Kraemer
10-28-2007 11:57:36
Hello, I just bought my first Ford 9N. Its been updated with a 8N side distributor "industrial" motor. My question is with the draught mode. My 9n will stop lowering the control arms when I stop moving the height control arm I any position. I was under the impression that the 9N's were either in the up position or the down "draught" position. Do I have 8N hydralics?? I was thinking that maybe they updated them during the engine swap. Any information would be appreciated. Thanks, Mark
soundguy
10-28-2007 17:10:10
 Re: 9n hydralics or 8n?? in reply to Mark Kraemer, 10-28-2007 11:57:36
You -CAN- get the 9n 3pt lift to 'look' like position controll hyds as long as there is nothing working ont he toplink linkage. To mow with a 9n, a set of check chains will work nicely.
Soundguy
Mark Kraemer
10-28-2007 17:40:39
 Re: 9n hydralics or 8n?? in reply to soundguy, 10-28-2007 17:10:10
thanks soundguy, thats basically the answer I needed. Cant wait to test her out this week!!
Areo
10-28-2007 15:52:14
Is it possible that it has ben retrofited with the "Zane Thang" it a fascimile of it that gives a 9N position control?
Areo
Mark Kraemer
10-28-2007 16:11:06
 Re: 9n hydralics or 8n?? in reply to Areo, 10-28-2007 15:52:14
It doesnt have a Zane Thang installed, I actually purchased a Zane Thang and was wondering if I was going to need it. The previous owner (a farmer that seemed to really know tractors) used this tractor to brush hog. This is what confused me. Anyone that can explain the hydralics of the 9N verus the 8N please help me out!!
Dunk
10-28-2007 14:10:30
 Dell!! in reply to Mark Kraemer, 10-28-2007 11:57:36
DELL, at least you are still showin up once in a blue moon!!
You (and yer sister) still have my prayers.
Dell (WA)
10-28-2007 14:36:29
 Re: Dell!! in reply to Dunk, 10-28-2007 14:10:30
Guys..... ...thanks for the prayers..... ...Dell
Dell (WA)
10-28-2007 14:02:58
Mark..... ..would it surprize you to learn that 8N sidemount engines eazily bolt to the 3-speed 9N/@N tranny, and is a common engine swap? It is "faster" than waiting 4-weeks to rebuild the original engine. Plus you gitt 26-hp of the sidemount 8N engine versa 23-hp of the original frontmount 9N engine.
NO, most likely you do NOT have 8N hydraulics. tip: 8N hydraulics have a little 3-in "flush" handle under yer right kneesies. This is a selector for either position (brush-hoggin') control in the "UP" position...or...horizontal for draught (plowin') control. Checker out..... ....Dell
Mark Kraemer
10-28-2007 16:17:12
 Re: 9n hydralics or 8n?? in reply to Dell (WA), 10-28-2007 14:02:58
Hello Dell, Thanks for the response. Well I dont have the little lever under my right knee. Only the trans. dipstick. What confused me was the previous owner (a local farmer) used this tractor to brush hog. (so he claimed) Is it possible to brush hog, etc. with this tractor. Or would I have been better off with an 8N? OR would I be OK with the Zane Thang? Thanks!!
old 9
10-28-2007 16:25:11
 Re: 9n hydralics or 8n?? in reply to Mark Kraemer, 10-28-2007 16:17:12
What makes you think you cannot bushhog with a 9-2-N ? Depending on your mower or the use of "stay chains" your tractor will "Get-r-done".
Dunk
10-28-2007 12:03:48
Open the inspection plate and see if it has yoke (2 pronged thing that goes down to the control valves)(I think).
Or I guess you could do it the easy way, and look for the draft/position control lever under the seat.
Or I may be off my rocker...
