pusher fan ?
Bruce L.
10-28-2007 12:02:20
I ws running the old N that i have for sale and noticed it has a 6 blade pusher fan. Is this a option fan that was used alot or is it a good find ? Must be good to keep weed seeds and grass off the rad. I have tractor in ads for sale in CT .for $1300
old 9
10-28-2007 16:17:18
 Re: pusher fan ? in reply to Bruce L., 10-28-2007 12:02:20
My 41 9-N has a pusher fan, I realy notice it plowing snow , much less COLD air going over you. Joe
Dunk
10-28-2007 12:27:05
 Well, Bob... in reply to Bruce L., 10-28-2007 12:02:20
Well, Bob...
Yes the heat on the operator is (could be) a factor, but since one is still operating the tractor in a forward gear, wouldn't one still be passing thru the heat?.
Now for one of the very few things I know about operating a bulldozer.
When using a bull dozer to push up a fire into a pile, a pusher fan would be very desirable, as if one has a puller fan all of the fire, sparks, and smole are sucked onto the engine and across the operator.
Not a good plan..
I know of one dozier that had a puller fan that was burned up, because the operator didn't realize this fact.
No it wasn't me.
DennyF
10-28-2007 14:41:53
 Re: Well, Bob... in reply to Dunk, 10-28-2007 12:27:05
Spent over 10 hours yesterday on a 30HP Kubota 4x4 w/loader, pushing brush into fires. Would've much sooner had a track loader (done that too). Several windrows of debris from logging, Probably 500 feet long had it been one continuous windrow. We had someone use a dozer w/brush rake to make the windrows this summer.
Didn't set the Kabookie on fire, but had the front tires (industrials) warmed up a few times. ;o)
Worst part of the job, was that the wind kept changing direction during the day. Dog wouldn't let me be last night when I got home, likely thought I was a 200lb slab of hickory smoked bacon.
Bob
10-28-2007 12:10:16
I never could figure out the "pusher fan" thing. What is the difference which way the fan blows... the reverse-flow fan would simply slather the BACKSIDE of the radiator with debris, rather than the front!
I'd guess the reverse-flow fan would make the operator a LOT more comfortable in HOT weather, though!
Tom N MS
10-28-2007 16:10:44
 Re: pusher fan ? in reply to Bob, 10-28-2007 12:10:16
JMO but I believe you'd get less stuff on the back side with a pusher fan. A few weeks ago I swallowed a cotton basket full of broom straw bloom. Straw taller than the tractor..Anyway,using this for an example, I believe it would take lots longer to clog up the back side with a pusher in grass like this--as compared to the normal puller..JMHO but this is my story and I'm sticking to it...
