ORC not coming off
71powerking
10-29-2007 16:14:47
I"ve been trying to get this orc off for the past couple of weeks without breaking anything, but I"m not having any luck. I don"t see any pin inside when I line up the grease holes. I can"t see thru to the other side at all, I"m looking at the pto shaft I think. COuld the orc have gotten twisted around on the shaft? I"m running out of ideas other than cutting it off. ANy ideas would be greatly appreciated.
chuck
Dave H
10-30-2007 12:00:40
 Good Info in reply to 71powerking, 10-29-2007 16:14:47
I think i wil try to get the one off my 8N today since I now know how they got there in the first place.
JMOR
10-29-2007 18:14:03
 Re: ORC not coming off in reply to 71powerking, 10-29-2007 16:14:47
third party image
At the risk of telling you something that you already know, you must leave the PTO in gear such as to hold the inner sleeve stationary, as you rotate the outer part and look for alignment of holes in inner & outer. Then you can see and drive the roll pin out.
Hope of some help.
71powerking
10-30-2007 09:55:39
 Re: ORC not coming off in reply to JMOR, 10-29-2007 18:14:03
THANK YOU!!!!! That is exactly what I needed. I will let you know how it turns out.
chuck
soundguy
10-29-2007 18:06:47
You say that you can't see a pin when you line up the grease holes.. yet you can't see al the way thru... 2 mutually exclusive comments..
As the others said.. line it up and run a drift thru..
soundguy
OH Boy
10-29-2007 16:40:53
does it still spin on the pto shaft in one direction? It is held on with a roll pin and you have to turn ORC in the shaft until you line up the pin with the grease zerk holes, then you can drive out the pin and it will slide right off.
old 9
10-29-2007 16:40:22
Yes the holes will not always line up. Put a drift punch in the hole and rotate the orc backwards untill it lines up. Small hammer and it is out, simple.
