Part Number Needed
Ritt
05-25-1999 04:31:47
I need a part number for the bearing that fits on the bottom of the drop spindle for the front axel. The bearing I got from the dealer has alot of slop. The dealer gave me part # CONN3123B. Also is there a lower grease/dust seal? or should the bearing fit tight enough to serve this purpose. Thanks for the help.
bg
05-25-1999 05:30:46
 Re: Part Number Needed in reply to Ritt, 05-25-1999 04:31:47
The number from the master parts catalog is a 9N 3123-B for 9N through NAA
Don B
05-25-1999 19:04:57
 Re: Re: Part Number Needed in reply to bg, 05-25-1999 05:30:46
The bearings you got from the dealer IS correct.9N part number Bob listed was changed to the Conn number.No seal on the bottom,but there is one on the top.Don
Ritt Thanks Guys---- No message
05-26-1999 04:21:19
 Re: Re: Re: Part Number Needed in reply to Don B, 05-25-1999 19:04:57
