New PTO shaft...what a difference!
Britcheflee
10-30-2007 13:26:45
I am extremely happy.....got my new pto shaft and replaced it in minutes.....then fired up the old gal and with some trepidation engaged the pto - previously there was a nasty rumble/grinding noise from what appeared to be inside the transmission....turned out it was the old bearing on the pto which was kaput....now it sounds sweeet!
attached the new ocr and cutting a length off the brush hog drive line so should be able to give the brush hog a test run after a cup of tea.
Lee
LeeMo
10-30-2007 14:15:55
 Re: New PTO shaft...what a difference! in reply to Britcheflee, 10-30-2007 13:26:45
Isn't that nice when the nasty noise is gone. Those bearings can really make a racket. Njoy your mowing !!
