Order Ford 8N Parts Online
Wiring Harness for lights 8N
Ande
10-31-2007 05:20:20
Wondering who sells the wiring harness for the lights,and what you folks feel is the best one.Time for lights here on my 8N
Ande
soundguy
10-31-2007 05:55:31
 Re: Wiring Harness for lights 8N in reply to Ande, 10-31-2007 05:20:20
Amazingly enough, a 'lamp' harness can be made from about 3' of 14awg wire and a few ring terminal ends and a lamp switch.
DonB carries a premade harness. i loked at the aprts section here but did not see one.
Pick up power from the load side of your ammeter.. IE, wire your lamp switch to the same terminal that the ignition switch gets it's power from.. run that short 4" wire from there to the lamp switch, then from the lamp switch forwar to one lamp, then parallel a line over across to the other lamp. For quick and dirty instalation.. tha's al there is to it. To make it 'better', I usually will run a ground wire from the block up to the lamp housing and make sure the lamp shell is grounded by using a star washer.. I then also parallel this ground wire over to the other lamp... this way the lamp does not have to rely on 50 year old reust sheetmetal connections for a ground path. Like I said about 3' of wire and 4 ring terminals for the 'basic setup' and add another few feet and terminals if you run grounds. Adding some spagetti looming to the wireing is another 'plus'.. though not expresly needed.. but nice to have.
Make sure you use a lamp switch that has a fuse holder, OR wire in a fuse holder in the short 4" wire fromt he power feed to the switch.
6v 35w lamps consume 5.83 amps each
6v 55w lamps consume 9.16 amps each ( if you can find 55w lamps )
12v 35w lamps consume 2.91 amps each
12v 55w lamps consume 4.58 amps each.
Size your fuse by adding your lamp current draw up and then rounding up to the next 'common' fuse size.
IE.. (2) 6v 35w headlamps will consume about 11.66 amps. I'd go with a 15a fuse.. possibly fast acting. if you have a tail lamp on this circuit that jumps to 17.5a.. thus requiring a 20a fuse.. again.. fast acting is my preference.
By placing the fuse holder in the small feed wire to the lamp switch .. you protect everything upstream.. including faults that may occur if the lamp switch fails internally and shorts to the housing.
Soundguy
Too Tall
10-31-2007 09:20:44
 Re: Wiring Harness for lights 8N in reply to soundguy, 10-31-2007 05:55:31
Soundguy,
Not to split hairs with you, but your calculations for current don't account for the inrush current when you first turn on the lights.
When I sized my fuses I went with a service factor of about 2.5 (Two 55W 12V lights pulling a calculated 9.17A on a 25A fuse)
Have you used fast blow fuses successfully when going up only one step over the calculated load?
When I've tried this, I ended up blowing a lot of fuses.
Not trying to pick a fight - just trying to learn
TooTall
Dell (WA)
10-31-2007 14:39:54
 Re: Wiring Harness for lights 8N in reply to Too Tall, 10-31-2007 09:20:44
Too Tall..... .according to a hand written note in my N-Ford MPC (master parts catalog) the OEM 6-volt fuse, (p/n: B-14526) was rated at 20-amps. But you had to buy the 5-fuse replacement tin; p/n: B-14527. This is from an outfit that sez the OEM battery is p/n: 2N-10655C; "Battery, domestic 13-plate". Doesn't say 'nuttin' about it being 6-volts or size 1A, altho it does say that it uses 3-redcaps (p/n: 2N-10720).
Me? There's 'nuttin' wrong with using 25-amp fuzes. My theory..... fuzes prevent the smoke from escaping and along as they go "poof" first, that is all that matters..... ....Dell, retired electronics engr
