Pulley fell off generator
reddogge
10-31-2007 12:51:27
My pulley fell off of the generator on a 9N today. From looking at the shop manual I think I need the lockwasher and nut. Do I need a clip for the end? Also is it threaded right or left and how do you keep the armature from turning when you thread the pulley on?
Thanks.
old
10-31-2007 17:30:44
 Re: Pulley fell off generator in reply to reddogge, 10-31-2007 12:51:27
That nut really isn't all that special. Normal treads and to be able to get it tight as it should be you almost need an impact gun to do it. If you remove the genny and take it to town with you you should be able to find a nut that will work and a lock washer also and yes you need the washer
reddogge
10-31-2007 19:35:46
 Re: Pulley fell off generator in reply to old, 10-31-2007 17:30:44
Thanks old,
But how do you keep the armature from turning while you are threading the pulley on and the nut? It seems to spin freely when you try to thread them on.
old
10-31-2007 20:57:21
 Re: Pulley fell off generator in reply to reddogge, 10-31-2007 19:35:46
Thats why you need an impact wrench they turn fast enough to keep that from being a problem
reddogge
11-01-2007 05:43:15
 Re: Pulley fell off generator in reply to old, 10-31-2007 20:57:21
I see. Thanks for your help. The threads are getting very worn on the armature so that may be the problem.
old
11-01-2007 06:36:43
 Re: Pulley fell off generator in reply to reddogge, 11-01-2007 05:43:15
If thats the case you may need to replace it or get it rebuilt. Or you also may need to find another genny for parts to fix that one.
