Order Ford 8N Parts Online
New to me 49 8N with no hydraulic power to lift.
Roger Allen
11-02-2007 18:54:47
Hello all, I have a 1949 8N with no power to the 3 pth, the lift arms can be moved up and down by hand. I got it this way 2 weeks ago. I have manuals coming. I have heard the automatic relief valve may be the problem, is that common? The fluid shows full on the dipstick. Where is the best place to start troubleshooting? Thanks for your help, Roger
Sean (TX)
11-02-2007 20:01:36
 Re: New to me 49 8N with no hydraulic power to lift. in reply to Dunk, 11-02-2007 18:54:47
Should go down without a implment...Just not as fast...
Roger Allen
11-02-2007 20:07:53
 Re: New to me 49 8N with no hydraulic power to lift. in reply to Sean (TX), 11-02-2007 20:01:36
Maybe it is cold, I did not run it long. I will try it in the morning. Thanks for your help. Roger
Sean (TX)
11-02-2007 18:57:16
 Re: New to me 49 8N with no hydraulic power to lift. in reply to Bob Jones, 11-02-2007 18:54:47
Is the lever at your left heel pushed to the rear?
Roger Allen
11-02-2007 19:05:38
 Re: New to me 49 8N with no hydraulic power to lift. in reply to Sean (TX), 11-02-2007 18:57:16
I will check that and reply. Thanks
Roger Allen
11-02-2007 20:01:35
 Re: New to me 49 8N with no hydraulic power to lift. in reply to Roger Allen, 11-02-2007 19:05:38
You guys are good. That worked but it won't go down. Does it have to have an implement on it?
theviperr
11-02-2007 18:58:47
 Re: New to me 49 8N with no hydraulic power to lift. in reply to Roger Allen, 11-02-2007 18:54:47
Did you by any chance take the PTO out of gear?
The PTO has to be turning for the lift to werk.
Roger Allen
11-02-2007 19:35:56
 Re: New to me 49 8N with no hydraulic power to lift. in reply to theviperr, 11-02-2007 18:58:47
Well I think I got a better deal than I first thought. I thank you both for the tip. I will be glad to get the op man so I won't have to ask silly questions. Without an implement on the lift I am guessing it is not suppose to go down with the lever? It went up but not down with the lever. Later Roger
Roger Allen
11-02-2007 19:03:45
I will check that and see if it works. Thanks
soundguy
11-02-2007 22:13:11
 Re: New to me 49 8N with no hydraulic power to lift. in reply to Roger Allen, 11-02-2007 19:03:45
Try some weight on the lift. i fthings are a bit rusty int he lift cover where the upper lift arms are.. it may be holding it up with no load.
If that isn't it.. pull the dipstick inspection cover and make sure the control valve is moving in and out of the pump freely as you move the handle..
soundguy
Dunk
11-02-2007 19:00:01
Well, dayum..
I got my name wrong agin...
