ford alternator
9N13830
11-04-2007 06:06:58
Dunk are you pulling my chain or do you really think that is a chevy alternator. Part number 213-3014 Nappa
ericlb
11-05-2007 04:24:26
 Re: ford alternator in reply to 9N13830, 11-04-2007 06:06:58
im going to pick motorcraft, based on the width of the winding band between the 2 aluminum halvs, and tha absence of the plug for the voltage regulator in the top of the rear half, if we could see the hookup on the back it would be a no brainer, i also compared it to the pic of how to wire the thing up witha idiot lite or diode and the pic of the 851 in the parts and pieces section which is definatly a ford alternator, his wont charge though, is there a reason why you dont run a fan on the alternator behind the pulley?
Dunk
11-04-2007 12:50:01
LOL!!
I'd bet on it, mine is a 6 volt, positive ground, Chevy alternator, that I had an alternator shop build for me.
Just so that you understand Dell's "Hakeem's Razor"
"All things being equal, the simplest solution tends to be the right one."
Dell (WA)
11-04-2007 07:19:07
third party image
YES..... .According to Hakeem's Razor, that is the popular and cheap Delco 10-SI alternator with built-in voltage regulator used by Chevy and other GM products. Commonly used for alotta 12-volt conversions on different vehicles including motorboats and tractors..... ..Dell, a 12-volt advocate for the right reason
9N13830
11-04-2007 12:52:24
 Re: ford alternator in reply to Dell (WA), 11-04-2007 07:19:07
Well i just called nappa and this is a alternator off a 78 ford bronco just what i ordered?
Dunk
11-04-2007 12:59:50
 Re: ford alternator in reply to 9N13830, 11-04-2007 12:52:24
I guess we lost that bet, huh!!
Ross Pugh(NC)
11-04-2007 16:33:21
 Re: ford alternator in reply to Dunk, 11-04-2007 12:59:50
I don't know 'bout that, Dunk, you know most of thest parts pickers just know what the computer tells 'em and that is only as good as the kid workin' the keyboaard. I would not bet on 'em being right.
JMOR
11-05-2007 06:41:54
 Re: ford alternator in reply to Ross Pugh(NC), 11-04-2007 16:33:21
third party image
"Shape" talks.
