Unknown Xmission
Cryptkeeper
11-04-2007 14:45:58
So, I have 9N and on the right side (seated), I have a hole in the Xmission. Inside the hole (grommeted) about 1 inch in, there is a 1" round shaft. It has a hole in the center of the shaft which is threaded for a 3/8" bolt.
I'm sure it aint a Sherman, I cant see it being a Hupp either.
Anybody have ANY idea what this puppy is or where I can get some info on it?
Thx guys
Cryptkeeper
11-06-2007 17:18:13
 Re: Unknown Xmission in reply to Hobo,NC, 11-04-2007 14:45:58
jimNCal said: (quoted from post at 03:13:40 11/05/07) CK,
I need a bit more description on the shaft you see in there. Does it have fine splines and is actually about 5/8" in diameter? If so, my guess IS a Hupp.
OR, is it actually about 1/2" in dia with a flat spot and threaded for a 5/16" bolt? If so, my guess is F&T O/D. This one tapers to about 3/4" as it goes farther in.
I'm not familiar enough with the Funks, Parkers, & Hieslers to pick one from a description of the shifter shaft. Sorry,
Jim
Jim & Sean, me thinks we are getting closer to identification. This puppy has the tapered shaft with a flat spot on one side.
NOW, where can I get info on the possible culprit (F & T) Xmission.
I would like to find/buy a handle to see what silly gear I am in?
Anybody got idears?
Thx Guys
jimNCal
11-07-2007 06:48:28
 Re: Unknown Xmission in reply to Cryptkeeper, 11-06-2007 17:18:13
I have a handle for your F&T. You have there O/D and regular gearing only so it sounds as tho you're in O/D with the described speed. The one I have was given to me broken and is now being parted out.
E-mail me directly. Even tho this community tolerates it quite a bit, I don't care much for doing a lot of business on the forum.
jim
Sean (TX)
11-05-2007 03:54:51
jimNCal said: (quoted from post at 23:22:38 11/04/07) Sean,
You still looking for an Aux trans for your tractor? I was putting together a table full of Combos today and remembered you trying to help me out some months back. Time to make you a good deal.
I'll have (4) ready to go by the end of this week. Only (1) is spoken for. I have plenty of input shafts for those that may need to be set up for the later 100 series.
Jim
Email sent...
Sean (TX)
11-04-2007 18:22:38
 Re: Unknown Xmission in reply to Dunk, 11-04-2007 14:45:58
Thanks for chimeing in Jim...Had not heard of the Funks, Parkers, & Hieslers...
jimNCal
11-04-2007 19:22:38
 Re: Unknown Xmission in reply to Sean (TX), 11-04-2007 18:22:38
Sean, You still looking for an Aux trans for your tractor? I was putting together a table full of Combos today and remembered you trying to help me out some months back. Time to make you a good deal. I'll have (4) ready to go by the end of this week. Only (1) is spoken for. I have plenty of input shafts for those that may need to be set up for the later 100 series.
Jim
Sean (TX)
11-04-2007 17:19:23
 Re: Unknown Xmission in reply to old, 11-04-2007 14:45:58
I wonder what position it is in? Have a hand held GPS? You can check your speed in all the gears... Here is a speed test I did a while back... Link
Cryptkeeper
11-04-2007 17:13:42
 Re: Unknown Xmission in reply to MikeT, 11-04-2007 14:45:58
Thx Sean, I mow FAST !!!
Appreciate yur quick answers. Maybe sumbody knows more 'n I do!
Sean (TX)
11-04-2007 17:11:33
 Re: Unknown Xmission in reply to KCM, 11-04-2007 14:45:58
Im pretty sure the F&T was made by sears or wards...Looked at the pic again...You may be right...That could be a bolt holding it on....I know I guy that had a couple in his shed....No levers thou...I didnt take a close look. I have no use for a over drive...
Cryptkeeper
11-04-2007 17:04:13
 Re: Unknown Xmission in reply to Tim, MI, 11-04-2007 14:45:58
Sean, sure a shame I aint got no leaks. Hate to split it. Sems like the Overdrive Xmission has a bolt. Iff'n it is long enough, might be that one. I gotta take a closer look.
Somebody thought I might have a Sears?
Thx
Sean (TX)
11-04-2007 16:47:25
 Re: Unknown Xmission in reply to Mike OH, 11-04-2007 14:45:58
Looked at Smith's sight again...Looks like the F&T shifter shaft sticks out too...Looks like only one way to find out....Split it!! Must be another reason to split it...New clutch?...Tranny input seal leaking? BTDT not as hard as it looks...Just dig inthird party image
Cryptkeeper
11-04-2007 16:27:20
 Re: Unknown Xmission in reply to Carl (NH), 11-04-2007 14:45:58
Nope, iff'n you look at Smith's site, the lever attaches to a shaft that extends out of the hole. My shaft does not extend out of the hole.
s no idea what this is?
Thx 'n boy am I confused
Sean (TX)
11-04-2007 16:10:19
 Re: Unknown Xmission in reply to Dave H, 11-04-2007 14:45:58
You bought a hupp lever and it didnt fit?
Cryptkeeper
11-04-2007 15:57:05
 Re: Unknown Xmission in reply to TheOldHokie, 11-04-2007 14:45:58
Well as I said it is on the right side as you are seated. The hole is right behind the right steering arm as the wheels are straight.
I went to Smiths, but cant tell what it is (the handle will not fit over the shaft as it is inside about an inch.
Pics would prolly not be of benefit, cause only thing you can see is a hole with a shaft 1" inside. The shaft is 1/2" dia.
Any other sites or ideas?
Thx agin
jimNCal
11-04-2007 18:13:40
 Re: Unknown Xmission in reply to Cryptkeeper, 11-04-2007 15:57:05
CK, I need a bit more description on the shaft you see in there. Does it have fine splines and is actually about 5/8" in diameter? If so, my guess IS a Hupp. OR, is it actually about 1/2" in dia with a flat spot and threaded for a 5/16" bolt? If so, my guess is F&T O/D. This one tapers to about 3/4" as it goes farther in. I'm not familiar enough with the Funks, Parkers, & Hieslers to pick one from a description of the shifter shaft. Sorry,
Jim
Sean (TX)
11-04-2007 15:47:36
 Re: Unknown Xmission in reply to Jerry/MT, 11-04-2007 14:45:58
We need pics...
Sean (TX)
11-04-2007 15:41:26
 Re: Unknown Xmission in reply to GB in MT., 11-04-2007 14:45:58
Sounds like sitting in the seat it is by his right foot. Could be a Hupp or a F&T...
Ken Crisman
11-04-2007 15:15:12
 Re: Unknown Xmission in reply to Cryptkeeper, 11-04-2007 14:45:58
Is that hole on the left side as you sit on the seat . If so , it's a Sherman . Go to this site : ntractor but add the word club & ask Jim Bills . He's got alot of knowledge about all the auxillary transmissions . Or go to John Smiths site & check with him . HTH ! I'm curious what you have myself . A pics would've helped more , so in the future post a pics along with the question . I'll check the site also & see what he tells you . If ya wanta , let me know what you learn either way . God bless, Ken
